Hello,
I have a question:
what would be the right procedure to download the geo-reference files from the Reach M + module?
The Reach M + is standalone without base station.
Is it necessary to start a survey for each mission before each flight?
Or how can geo-logging be obtained per flight mission for the photogrammetric photos of the flight?
my first copter doesn´t have a base station like Reach RS+ or Reach RS2.
it has only the Reach M+ module with the Hotshoe connection on my Sony A6000 camera.
And i wish to extract the time and position stamps like direction, longitude and latitude.
what i wish to know, if i must or if i can start an data log for every flight separately.
Where can i find an tutorial for this procedure?
Thank you very much!
A “survey project” is an interactive thing and not used for drones. For a standalone Reach, enable the position and the raw logs. Once enabled, logs will be recording each time Reach is powered up.
You will still run a post-processing job to extract the timestamps from the raw log.
I don’t think there is a tutorial for the method you plan to use, but you should still read about post-processing in the documentation and then adjust it for what you are doing.
