Hello, I received my rs3 a few days ago. Everything seems to work correctly but I have a problem with the sim and data connection. Every time I turn on the rs3 the data is turned off, I have to activate it manually all the time and it often takes multiple attempts.
I use a m2m sim from Things Mobile (which I already use without problems with other manufacturer’s gnss receiver). The advantage of this type of sim is that it is multi operator so wherever I am it chooses the network with the most signal. As per the operator’s instructions I entered as Apn TM and enabled roaming. When I manually activate the data connection via Emlid Flow everything works properly but when I turn the rs3 back on the data is disabled again. Do you have a solution?
sorry i solved it myself by removing the APN
Hi @MauroBZ,
Welcome to our community forum!
Thanks for confirming that remove the APN solve the issue with the SIM Card.
