Purchased 2, RS2 units in April 2021 and I'm delighted with the product. I use as Base & Rover when NTRIP is not available. Today was such a case, however during the survey the Base was blown over and the gray/white upper case was badly damage, as section of its shell broke off. Delighted the weather was good so no water damage. I need to replace the gray/white upper shell to keep water and dust proof. Is it possible to purchase this upper shell and seal the unit? I tested the unit this evening and it's working properly, but will need to replace the upper shell. Any assistance would be grateful received.
I’ve noticed you contacted us via email, and I’ve just answered you. Let’s continue our discussion there to avoid confusion.
