Hello, I am using REACH RS+ AND REACH M+, i collected the following data in the picture attached, but I dont understand the meaning of the data obtained, can anyone help please
Hi @rayanskaff6,
Welcome to our community!
The headers of these columns are as follows:
The first column is GPS time.
Receiver Position: XYZ components in m.
Q: the solution quality. If Q = 5, it means a Single solution.
ns: number of valid satellites for solution calculation.
The sdn, sde, or sdu means N (north), E (east) or U (up) component of the standard deviations in m.
The absolute value of sdne, sdeu or sdun means square root of the absolute value of NE, EU or UN component of the estimated covariance matrix.
Age: time difference between the observation data epochs of the rover receiver and the base station in seconds.
Ratio: the ratio factor of ʺratio‐testʺ for standard integer ambiguity validation strategy.
Are you recording a position track for your project? Or did you want to collect separate points?
