Hello !!! How can I delete a local coordinate system that I added manually?
Hi Luis,
Depends on what device with ReachView 3 you use. On iOS, this functionality is already available. On Android, you can only ignore already-created systems. We’re working on making the two systems equal in this respect.
Thank you Polina! i use android. I got confused in a parameter and wanted to delete it.
Luis,
I see! For now, I can only suggest creating a new system with the distinguishable name, the one that’ll tell you that this parameter is correct.
Luis,
Just wanted to let you know that with ReachView 3 6.16 update, you can delete the custom coordinate system on Android as well. So you don’t need to make up different names for systems if you just misplaced some parameter
Great !! thank you
