Anyone having some issues when changing configurations in ReachView 3?
I have both RS+ and RS2 and i got the issue in both of the. The RS+ was in Correction Input As shown in this video 20210514_162153.zip (2.3 MB) . I tried also via the ReachPanel but i get this message:
Did I get correctly that you tried to configure Correction input via Serial?
May I ask you to share Simple system reports from your units so that I could check other settings? It will also help us to reproduce the issue correctly.
The issue happened after i factory reset, after i refreshed the page, in both Reach Panel and in ReachView 3 i get a message saying it couldn’t apply the changes.
Only after restarting both RS+ and RS2 i was able to change them
The behavior is indeed weird. We’ve tested 26.1 a lot but never faced such issues.
Does the issue still repeats on both Reach RS+ and Reach RS2?
May I ask you to email us at support@emlid.com with the Full system report from 26.1? I believe it will give us more info for investigation and reproducing.
Hijacking this too because of similar issues with my M+ , fw 26.1 . Accessing the GNSS settings via RV3 (v 6.0), and for instance going from Fix-and-hold to Continuous , then clicking the blue Save button : the button image starts spinning, but nothing happens for at least 20 seconds. Going back and retrying almost never worked. I usually had to close + restart RV3.
