Hi Everyone,
I would like to use both Reach RS+ units as rovers, without the base station, for a survey in Greece. Other than NTRIP, what is the best way of correcting the data, so that I get cm-accurate measurements.
Thanks!
Hi Everyone,
Thanks!
If you have a CORS station nearby you can post-process your data up against that.
But then we are talking PPK and not RTK, so your data will be immediately cm-precise.
Thanks for your response. Unfortunately, there isn’t one close enough. Are there other options?
Maybe another RS+
Hi @ljr,
As a source of base corrections, you can use another Reach RS+ unit or an NTRIP station. This is the only 2 ways of getting centimeter accuracy. For RTK you always need a base station either local or remote.
