Hello,
In the Flow APP, in the “Corrections” section, the information “Correction date” is displayed, expressed in seconds.
Does this represent the time in which each correction is received?
What is the ideal limit for a reliable fix?
That’s pretty much correct. From your other post the Age was 2.2 seconds which is fine. I’m guessing you have the receiver set to 1Hz and it’s running just a little slower at 0.45Hz. Basically you are only getting a correction on that interval. This could pose a problem if it goes much higher if you are doing work while moving fast like in a vehicle or on a drone.
