Hi all,
I would need some help to understand the correct way to use RTKlib “positions” tab for Base. For example I have a known point with h=10.00m and the Antenna Reference Point 1.50m above that point.
Is this correct?
Antenna height= 11.50
Antenna Type = * - Auto from Rinex file (In my case I have a Trimble GPS as Base)
Delta U = 0.00
Or is the same if I use:
Antenna height= 10.00
Delta U = 1.50
Or is another way to reach to the antenna phase center correctly?
In the case or the Reach I know that the phase center on the base of the Tallysman antenna, I only need to know the base.
Thanks!
