Coordinate with a (1) or (2) or similar
Is there a way to change the name on the coordinate system?
Whenever I pick up permanent markers and localise the project on them, the name adds a (2) or a (1) to it, which I feel makes the final plan you give to your client looks amateurish and suggests that if we haven’t got enough attention to detail to even get the file name right, then what else did we not do right on site.
Hi @Ben_Minutoli,
Welcome to our Community Forum!
After localizing the project, you can rename the coordinate system by going to Project settings > Coordinate system > Use Custom. Then, tap the three dots next to the coordinate system and select Rename. To make it a bit clearer, I’ve also attached a screenshot for you to look over.
ahh there it is, awesome thanks Mohamed
