Coordinate system - GCPs error in Reality Capture
Hi guys,
I ran a mission yesterday and shot 2 GCP’s with RTK Fix using Reach RS2+ and when inputting them into Reality Capture they are not being recognised. I shot them in the standard GCS and the settings in R/C are epsg4326 - GPS WG84 - if these are incorrect could you advise on the correct system as I am a bit stuck.
Thanks
James
What is the CRS used by the NTRIP service?
I have just had a reply from them and the use ETRS89, so i guess I would need to transfer them into GCS?
In that case you’re collected GCPs are also in ETRS89.
In RC, you need to set that as your coordinate system.
That would be easier :joy: thanks Dave
Hi James,
I agree with Dave’s suggestion. In our previous conversation, we defined that your coordinate system is ETRS89 / Jersey Transverse Mercator. So you can use the GCPs collected in it.
