I logged about 4 hours of static data in rinex version 2.1 at 5hz but the file is 189MB and I need to it to be under 100MB to upload to OPUS. Is there a way to convert the data down to maybe 1hz or every 15 seconds? The rinex file .19O file extension. Let me know if there is a solution out there, thanks!
That is not a Reach file extension.
Still, you could try to open it in RTKCONV and use the interval option to thin it out to e.g. 1Hz.
Yeah I tried using it but im not getting and output .obs file. I have the interval option checked with 15 secconds, anything else I have to set inorder to get a converted .obs file?
EDIT: Figured out what RTKCONV settings to use.
HI @ryancjames94 in RTKCONV select interval (top rigth) 1 seg or 15 seg.
Greetings
you can use TEQC or GFZRNX to re-sample the file.
