Continuing the discussion from Power Module Battery Voltage/Current Scalers:
Hello community,
we have the exact same question as in the topic linked above:
- What are the voltage and current scalers in the power modul (ADC A2 and A3 channels)?
I have found a thread in the community forum about an experimental approach (estimating the current scaler from the charge, reported by the battery charger), but I think there could be a more direct answer to this.
Unfortunately the thread has no answer to this questions and digging through the documentation and other thread also didn’t provide an answer.
To our understanding there should be simple factor which we could use to convert the values from adc measurements which are between 0 and 5 V to the the actual value for our battery between 0 and 16.8 V and the current between 0 and 90 A.
We might be able to calibrate the voltage value ourselves but that seems just like a hassle and inaccurate.
Any other solution or known conversion factors?
Thanks in advance.
