I have written a program that controls my 4 motors of my boat (based on the navio2 examples).
When ardupilot isn’t running, everything just works fine.
But if I run ardupilot, to get access to the mavros topics, my program won’t work anymore.
I get this error:
Hi @rcommissaris11!
You can’t use ardupilot and your application in the same time, because they are using similar resources. Therefore this is a normal program execution result.
@rcommissaris11, delete check_apm was great idea, because it really fixes your problem. But right now you have new problem…
Your application and ardupilot use same motors, so you will get undefined behavior in time, when both programs try to change motor’s condition. Please, don’t use this hack in tests.
You can config your motors by QGroundControl. Have fun!
APM uses motors without your control. Therefore you should set Airframe as undefined or change motors for ardupilot in QGC. Otherwise, you will have a problem.
