I just begin to interest myself into a drone construction!
After looking the different feature of Navio+ I think it’s the best solution for me.
But i just want to be sure of one things: I want to turn my Raspberry Pi into a wireless router and I want to control the Navio card with the Wifi of the Raspberry Pi. It’s possible?
There could be extra latency between the control movement and the reaction, compared to a RC transmitter/receiver. Don’t use such a setup for racing or low/proximity flight.
If you already have a radio transmitter, the cost of a basic receiver with CPPM pass-through is insignificant and very useful at least for takeoff, landing and backup use. The new ones are also very small and light.
You need GCS failsafe set so it will not fly off if you lose the WiFi signal, and set to a height higher than anything you plan to fly around.
The joystick support in Mission Planner is more advanced, so maybe you should use that as your GCS.
If you use standard WiFi equipment the range will be limited, more than a RC transmitter. You should get a high gain antenna for the ground station and a decent USB dongle (with necessary drivers) for the drone.
If you don’t use WiFi for control (install an RC receiver) then it could still be a viable alternative to the 3DR radio for GCS telemetry and instructions.
