I cant get any response from the pin outs 7-12 on my edge module
i connected a servo on pin out 9 and tried different input and output combination but there was no response from the servo… channel 6 and channel 7 bar moves under channel monitor of the radio tab
tried changing gimbal types as well… no luck
using alexmos 2 axis gimbal for go pro, when connected to servo tester the tilt works…
Thanks, i figured myself as well… was trying different combinations and the exact same worked as you said… Gimbal is sorted
I also want a 5V from the middle pin for powering servos, is it possible? or should i use a bec for 5v and take out the signal and ground from the edge’s pinouts?
