Hi! I wanted to see if I could control a brushless motor via the pwm output on the board, I was just wondering if I could get some help of how to go about it.
As far as I know, for a brushless dc motor, the paramaters are usually:
50Hz Frequency.
1ms = zero throttle
2ms= full throttle
I tried to modify the code from the PWM example but when I hooked up the motor all that I got was a fast beeping sound.
I have a turnigy9x controller with pwm output, and when I use it with a brushless motor i usually have to put the throttle on the zero position and then lower it down to the max position for a few seconds to get control of it. So do I have to do something like that? should I send a timed 1ms pwm followed by a 2ms to gain control of the motor? Anyone that was able to set up a motor with the pwm output if you could help me I really appreciate it.
Thank you!
hi! I was able to make it work! I did a pwm pulse of 1000ms for a few seconds (than a music tone ringed on the motor) and afterwards I just tested the speed setting the values of the motor to1.1ms and 1.25 ms. Here is the code to anybody that may want to try it out:
Hello
Well, I’m really new to these stuff and i have a basic question (or let’s say a stupid one), In which language you are programming? and there is another question on weather we have a default set for motors on the Navio+ ? Please answer
