Consider including additional attributes
First off, good job for the automated attributes written for each point recorded in Emlid Flow v8.6 Android.
There are some additional attributes that are suggested for consideration.
  • At the top of list:
  • Receiver make
  • Receiver model
  • Receiver S/N
  • Project Name
  • Mount Point used for corrections
  • Coordinate System Reference Frame
  • Coordinate System Projection
  • Vertical Datum
  • Geoid Model
  • Linear Units
  • Where applicable, either in the attribute name, or its value, append with the units being written.
  • Height of Instrument (ARP)
    • The one attribute that ought to be considered eliminating is Antenna ht as this value should remain transparent to the user
Hi Kelly,
I’ve noted your request, thank you!
