from iPad to Navio2/Raspi3B+ doesn’t work, endless waiting for connection, does anybody know why?
Hi @masterklause,
Which type of connection did you try?
Hi, I just started the app on the iPad an waited for connection.
Both the ipad and the navio2/Raspi3B+ were in the same WLAN network.
Klaus
Hi Klaus,
Have you specified iPad’s IP address in /etc/default/arducopter
file?
Aaaah, that’s it
Thanks!
Is it possible to specify two or more IP adresses in this file, e.g. if I want to use one time the iPad and the other time the PC?
Yes, it’s possible. You can specify the second IP address as another TELEM. For example:
TELEM1="-A udp:<PC_IP_address>:14550"
TELEM2="-C udp:<iPad_IP_address>:14551"
Note, that you also may need to configure Serial parameters in QGroundControl. For -C
option, use SERIAL1 parameters.
You can read more about launching options in our docs.
Also, you’ll need to specify a new Comm Link in Application Settings of QGC on iPad as you use a non-default port for the second connection.
