Firmware image and ReachView version: V2.20.8
[System report]
Simple system report
app version: 2.20.8-r0
'wifi_status, interface: wlan0':
- wifi_mode: wpa_supplicant
- ip: 10.15.16.26
is_connected: true
mac_address: fc:db:b3:92:d4:30
ssid: Gokturk_wifi
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: serial://ttyMFD2:57600:8:n:1:off#rtcm3
type: serial
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: true
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
position output:
output1:
enabled: true
format: erb
type: serial
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: true
gps: true
qzss: false
sbas: true
snr mask: '15'
update rate: '5'
Hello ,
I’ve been using your rtk kit for a while. I didn’t have any problems during the first test flights.
I’m having trouble connecting to Reach. It didn’t turn on and it turned on and off as I understood from its lights (repeatedly repeating).
I flashed it again and installed the latest version.
I could not re-establish the Rtk connection.
The settings for arduplane, base and rover are as follows.
Arduplane setting:
Reach:
Reach rs:
Connection screen :
I use for this Rfd868x and set parameters Raw Data and clear ecc field.
Also try for connect over wifi (between Reach RS and Reach )
Connection running stable
Reach screen after connection.
Although GPS 2 is detected and position is sent, rtk correction is not transmitted on Reach
I need your immediate assistance to resolve this. How to debug it?
Thanks for your help
Hi Kadir,
It seems I’ve already answered to your email. However, I duplicate it here so other users can join the discussion and advise anything useful.
First, may I ask you to share your hardware setup photos so I can check if Reach is connected correctly to the flight controller?
Also, I’d like to ask you to update images in your first post as they can’t be loaded.
Thanks.
I checked the Tx and Rx pins and connected them with the cable that came with the Pixhawk.
Now I use Telem2 Port on Pixhawk
The result has not changed
GPS connection available, reach sends coordinates to autopilot, but correction data is not transmitted to reach.
Hi Kadir,
I checked all the screenshots you sent me in the email once again and it looks like everything is configured properly.
I assume there is might be an issue with wires. Is there any chance you have got another cable to test with it?
The cable in the photos I took was new. I got the same result as the previous cable
Hi Kadir,
We’ll try to replicate your setup to check where the issue might appear.
gleb.gira
(Gleb Gira)
December 4, 2019, 1:07pm
#8
Hi Kadir,
I’ve tried to reproduce your setup. May I ask you to change the following configurations:
Use GPS2 port instead of TELEM2 on Pixhawk.
Change GPS_TYPE2 parameter in the MissionPlanner from “1” - AUTO to “13” - ERB .
Let me know if it helps.
Hi Gleb ,
I tryed your suggestion .Changed port and type , status did not change.
I suspect the socket with the rx tx pins on the reach.
Is there a way to verify that correction received by reach ? Using ssh to access edison terminal ?
You may want to try an power reach from a separate bec I have noticed they are quite sensitive to power fluctuations many of those ports on the pixhawk cannot support large loads. telem 1 is its own 1amp circuit the rest share 1amp.
gleb.gira
(Gleb Gira)
December 9, 2019, 4:46pm
#13
Hi Kadir,
May I ask you to send System Reports for both Base and Rover?
Also, could you you please take a screenshot of incoming base corrections in the MissionPlanner?
Hi Gleb,
I run the system, made all the connections, and I got the reports.
ReachRS log;
- ip: 192.168.10.100
is_connected: true
mac_address: fc:db:b3:95:e4:71
ssid: Gokturk_wifi
base mode:
base coordinates:
accumulation: '1'
antenna offset:
east: '0'
north: '0'
up: '1.48'
coordinates:
- '37.86565182'
- '32.41805361'
- '1200.945'
format: llh
mode: float-and-hold
output:
enabled: true
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '1'
'1008':
enabled: true
frequency: '5'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: true
frequency: '5'
'1020':
enabled: true
frequency: '5'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '1'
qzss:
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: K104200201:***@212.156.70.42:2101/VRSRTCM31
send position to base: single
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: true
format: erb
path: ttyMFD2:57600:8:n:1:off
type: serial
output2:
enabled: false
format: llh
path: ttyGS0:115200:8:n:1:off
type: serial
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
compass: false
galileo: false
glonass: true
gps: true
qzs: true
qzss: false
sbas: false
snr mask: '10'
update rate: '1'
Reach log;
- ip: 192.168.10.108
is_connected: true
ssid: Gokturk_wifi
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
output:
enabled: false
format: rtcm3
type: serial
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: true
correction input:
input2:
enabled: true
format: rtcm3
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
position output:
output1:
enabled: true
format: erb
type: serial
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
compass: false
galileo: false
glonass: true
gps: true
qzss: false
sbas: true
snr mask: '15'
update rate: '5'
I tested the pins on reach rxpin show this:
Base correction is open, streaming;
Base correction is close, stopped streaming;
Oscilloscope display shows signal. But I don’t know if it’s true.
If there is no other problem, I would like to re-solder the socket’s soldering ways.
What would you think for that?
gleb.gira
(Gleb Gira)
December 11, 2019, 1:28pm
#15
Hi Kadir,
May I ask you to check the signal on the PixHawk UART TX pin with an oscilloscope? Please send us the photos of the display with enabled/disabled base corrections.
Hi Gleb,
I check your suggestions
Disable corrections;
Enable corrections;
Pixhawk tx pin connected Reach rx and I measure it.
gleb.gira
(Gleb Gira)
December 13, 2019, 2:27pm
#17
Hi Kadir,
Is it possible to connect your radios directly to Reach RTK and Reach RS? We want to check if your radio module can transfer base corrections.
Hi Gleb,
I did what you said, nothing changed . But today we made a detailed examination on reach and decided to re-solder the circuit paths.
RTK started working without the need for any other operation that gave the result.
Thank you very much for your help.
I will also share our recent research on accuracy.
system
(system)
closed
April 1, 2020, 4:22pm
#20
