Hello! I have purchased 3dr radio V2 the one which is on the photo. I am. Doing everything according to the guide. I have got emlid reach module. I turn on rover firstly. The radio blinks green, which means it is seeking another one. But when I turn on the base the 3dr radio is solid red and doesn’t communicate to the other. What can I do? How can make them work well togather?
Hi Georgi,
From the LED status, it seems that the internal parameters of the radios are not configured properly. Please, double-check them.
Note that the baud rate in ReachView tabs (Base mode and Correction input) should match the internal baud rate of radios. You need to select UART as the communication protocol if you connect the radios to the DF13 port.
