I’m totally new to the subject. I have configured Navio 2 with Pi3 and I can connect the copter to MP through UDP. I connected 915Mz radio. One to Navio through UART. Both unit green led’s are lit and still. I’ve done load settings through SIK radio configuration and everything is fine.But I can’t connect to the radio through MAVLink. I’ve checked serial port communication with /boot/cmdline.txt and it’s fine. But /etc/inittab file is empty.
I’ve tried starting with “sudo arducopter -C /dev/ttyAMA0” in putty and when this is running in putty I can connect to Mission planner from the ground control side to the quad.But if I close putty the connection get lost. Can someone help with this issue.
