Hello,
I am still new to the Navio2 and am trying to connect my telemetry radio to my mission planner. I am following this guide: APM 3.1 Video Series - Simple 3DR/MAVlink radio setup and use - YouTube but cannot get the final step.
I have my ground radio talking to my air radio, and I am able to fill in all of the data for both the local and remote info. However, when I then try to then connect mission planner to the board using my com7 with a baud rate of 57600, the connection always times out.
On my board I am running sudo ArduCopter-tri -A udp:“IP”:14550 in order to start ArduCopter, should I change this?
Finally, is there a way to check if my air telemetry module is attached correctly? I have it connected to the UART port on the board but it seems like there is a 1 mm gap or so between the front edge of the board connection and the back of the pinned connection (if this makes sense, I can upload a picture if not).
