Windows 10, Navio2 with Raspberry Pi3, Ubuntu 16.04 (easier to ssh to the navio2)
Can’t connect to QGroundControl v3.1.3 on windows 10
It’s that simple.
I connect the Navio2 to the windows 10 PC vie USB and open QGroundControl. QGroundControl never detects the Navio Unit.
Per the Docs:
Here you can specify IP of your ground station.
TELEM1="-A udp:127.0.0.1:14550"
#TELEM2="-C /dev/ttyAMA0"
Options to pass to ArduPilot
ARDUPILOT_OPTS="$TELEM1 $TELEM2"
-A is a console switch (usually this is a Wi-Fi link)
-C is a telemetry switch
Usually this is either /dev/ttyAMA0 - UART connector on your Navio
or /dev/ttyUSB0 if you’re using a serial to USB convertor
-B or -E is used to specify non default GPS
All lines marked ‘#’ are comments and have no effect.
For example, you’ll need to modify TELEM1 to point to your IP like this:
TELEM1="-A udp:192.168.1.2:14550"
Where 192.168.1.2 is the IP address of the device with the Ground Control Station - your laptop, smartphone etc.
My ip is 10.0.1.14 hence my command was pi@navio:~ $ TELEM1="-A udp:10.0.1.14:14550"
