Hello !
I’m working on a research project on driving a parachute with a raspberry, using the navio2 sensors.
in order to control the parachute i have 2 engines communicating in RS232 with the raspberrry (from the USB port into a com port)
Is there a way i can either drive them with the navio card, or do i have to make a pilot and guidance law by extracting the navio2 sensors data ?
Using the PWM output seems a no go, after discussing with the ardupilot’s devteam. I do believe that writing my own script will be the only solution. Fortunately i believe i can use a Lua script to get the parameters i need and run a software made to communicate in RS232.
