hi there,
i am very happy with the reach module.
i use youcors for corrections and its mm accuracy as said on the tin…
when i am at home i connect to my network and it all works fine but when i try my mobile network hotspot or my mobile broadband i cannot connect for love or money!!!
i am on the reachview ,make a new connection then the white box comes up and tells me to refresh but from there i cannot find the right ip adress …
i looked on the fing app for my hotspot ip but still no joy…
please help -)
Hi Jason,
Did you make sure that your phone is discoverable? You can do it in Portable hotspot settings.
Hi there.
The phone is discoverable and my laptop can connect to it …
Baffling
Thank you for your reply.
Is there something in reach view that I must do?
Jason,
What’s the LED behavior after creating a new connection in ReachView app?
Hi @jayairuav,
Can you clarify some of the following points, please?
What’s the distance between Reach and hotspot?
What firmware version do you have on your Reach?
In regards to iPhone X hotspot, does your cell carrier plan allows sharing the Internet via hotspot?
When using a Wi-Fi dongle, how do you power it in the field?
Does Reach connect to its hotspot?
Could you send full system report from Reach connected to Wi-Fi dongle?
Thanks in advance.
What type of phone? Apple or Android?
My reach will NOT connect to my iPhone UNLESS I connect something to my iPhone first. Then my Reach is able to connect.
Hi there.
thank you for your quick reply.
i have a mobile broadband device which is 4G and it all works on the same wifi network.
I.E , emlid reach device, mobile internet, smartphone.
the distance is within meters.
i have the latest version of the software.
the dongle allows connection as everything is connected.
The wifi dongle has a lithium battery it is a EE mobile broadband dongle and apparently the best device on the market and has 6 hours connection time and 30 hrs standby mode.
once i have asked the reach to connect to the corresponding WiFi …Ie smartphone, computer .
it connects perfectly…i have the ip address and can connect.
Simple system report
app version: 2.15.1-dev-r0
'wifi_status, interface: wlan0':
- wifi_mode: wpa_supplicant
- ip: 192.168.1.140
is_connected: true
mac_address: fc:db:b3:8e:53:6f
ssid: MY WIFI C365
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: ntrips://:alfie3001@am.youcors.com:2101/jayairuas#rtcm3
type: ntrips
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1008':
enabled: false
frequency: '1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: false
frequency: '1'
'1020':
enabled: false
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '0.1'
qzss:
enabled: false
frequency: '0.1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: Jason:***@am.youcors.com:2101/jayairuas
send position to base: 'off'
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '5'
i hope this helps.
thank you
best regards Jason
I have an iPhone X with 4G network
Hi Jason,
Sorry for late response.
Have you tried connecting to your iPhone at home or in the area without any known Wi-Fi networks? Could you please make sure that your iPhone isn’t connected to a known Wi-Fi network while you are trying to do it? Or did you finally manage to connect M+ to your iPhone’s hotspot and I can mark this thread as resolved?
