kash
(kash)
#1
I didn’t get GNSS antenna with Navio2 so I plan to use my other Ublox New M8N GPS receiver+Compass module.
I believe, I got to connect the GPS and Compass cables to Serial and I2C ports respectively on Navio2.
How do I configure it in “/etc/default/arducopter
Please see if the following is correct!
TELEM1="-A udp:127.0.0.1:14550"
#TELEM2="-C /dev/ttyAMA0"
GPS="-B /dev/ttyAMA0"
# Options to pass to ArduPilot
ARDUPILOT_OPTS="$TELEM1 $TELEM2 $GPS"
mlebret
(Marc Lebret)
#2
Hello,
Good guess for wiring,
Pay a little attention to the etc/default/arducopter settings:
TELEM1 is the address of your computer when Pi wifi is connected to your network.
So you will have something as TELEM1= “-A udp:192.168.1.1:14550”
TELEM2 will be your external GPS. It will be -E
TELEM2="-E /dev/ttyAMA0"
You can have a TELEM3="-C /dev/tty/USB0" if you have USB telemetry
Option to pass to Ardupilot is:
ARDUPILOT_OPTS="$TELEM1 $TELEM2"
When you have your new Navio2 GPS Antenna, you can use the two GPS without change of TELEM settings.
-E is the flag for External GPS, no need to define -B for Internal GPS.
When connected to mission planner (or QGroundControl) you have to set GPS2 parameters.
Marc
kash
(kash)
#3
Hi Marc,
Thanks for the detailed explanation, it’s crystal clear now
system
(system)
closed
#4
