Hello everyone.
Is it possible to connect two reach to a navio2, deactivating the Neo-M8n integrated in the board?
Thanks
Hello everyone.
Thanks
It’s possible. You can connect one to UART port and one to USB-UART converter yielding the ArduPilot config with the switch -B /dev/ttyAMA0
and -E /dev/ttyUSB1
or you can connect over two converters. What are you trying to achieve by using two Reach modules in this setup?
Hi. I’m trying to get redundancy
How do vibrations affect to USB connectors?
Thanks
These are pretty much negligible but two usb dongles might introduce a little weight shift to the side where they’re at. But I reckon this is also not that important unless you’re planning to build a slick racer drone.
