I am trying to connect the RS2 with the Matrice 300 RTK by WIFI (NO Ntrip), to be able to use it in areas where there is no mobile data coverage.
Do you know if there is any possibility to send the RTCM3 corrections over wifi?
I have seen that colleagues with “F9P” teams are already doing it, and I would like to do the same with my RS2.
Greetings.
Hi Domingo,
Yes, RS2 can send corrections over the Wi-Fi network: choose the TCP option in the Correction Input screen to make it work.
Please note that Reach’s hotspot range isn’t tailored for long-range communication, so you’d better connect both RS2 and your drone to a Wi-Fi network.
Hi Tatiana
Thank you very much for the information
Receives a warm greeting.
system
(system)
Closed
August 20, 2021, 7:19am
6
