Hey I am new to using the navio2 and quadcopters in general but I have some questions about receivers and transmitters.
I recently purchased a radiolink transmitter controller T8FB and it came with its own receiver R8EF 2.4GHz 8ch. I also bought an frsky D4R-II 2.4GHz ACCST receiver.
In my complete ignorance, I failed to do the proper research as to how to use or pair these two things. I know the Emlid Docs state that the navio2 is compatible with :
For ACCST (most FrSky transmitters)¶
FrSky D4R-II 4ch 2.4Ghz ACCST Receiver
FrSKY V8R7-SP ACCST 7 Channel RX with composite PPM
FrSKY D8R-XP
For FASST (Futaba & some FrSky trasmitters)¶
FrSky TFR4 4ch 2.4Ghz Surface/Air Receiver FASST Compatible
As I mentioned before I have a FrSky D4R-II receiver.
Now that I have explained my situation, my question here is
Can I use my Radiolink transmitter controller with the receiver it came with?
Can I use the FrSky receiver I own with the transmitter from Radiolink?
Or do I return the Radiolink transmitter controller with the receiver it came with and try my best at finding a low cost Frsky radio controller that is compatible with the FrSky D4R-II receiver?
Any help would be greatly appreciated thank you.
