I have the same problem as I can configure vodafone and tim sims.
I have already seen the video tutorial and disabled the tab pins.
thanks
regards
Hi Aldo,
Have you tried using APNs? What’s the firmware version on your device?
Hi Tatiana,
how can I set APNs?
my firmware is 2.20.7
Hi Aldo,
You can enter it in the Mobile data tab of ReachView.
Also, may I ask you to share the screenshot of your Mobile data ReachView tab and the Full System Report generated on this device?
hi Tatiana,
I have the complete report with tim italia card
the button to activate the mobile network does not activate if I click
I forward you the report
I tried to insert the following APN
wap.tim.it
ibox.tim.it
unico.tim.it
link to download the report
https://drive.google.com/open?id=1lHM91CQCp6lzm0JiYP0rnYhfHDmtMVcT
Hi Aldo,
I’ll check the report and write back to you.
Hi Tatiana
I solved the problem
I entered APN and activated the voice share mobile data from reach in hotspot mode
then I turned the RS2 reach off and on again
thanks
Hi Aldo,
Great to know it!
