Has anyone successfully gotten hostapd working with the navio RPI4 image (buster OS) to setup the RPI 4 as an access point?
I am following the standard setup configuration using hostapd: https://raspberrypi-guide.github.io/net … cess-point to have the rpi operate as an access point, however I am running into a bunch of issues that result in the access point not being broadcasted.
In the dhcpcd.conf file, I have the following settings:
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
In the dnsmasq.conf file I have the following settings:
interface=wlan0
dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
domain=wlan
address=/gw.wlan/192.168.4.1
In the hostapd.conf I have the following settings:
country_code=CA
driver=nl80211
interface=wlan0
ssid=dragonflite95
hw_mode=g
channel=6
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=MYPASSWRD
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Now it seems even with the nohook wpa_supplicant in the dhcpcd.conf, the wlan0 is still getting caught up on it.
Here are some diagnostic tests:
pi@navio:~ $ hostapd -dd /etc/hostapd/hostapd.conf
random: getrandom() support available
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Using driver-based roaming
nl80211: TDLS supported
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Failed to set interface 3 to mode 3: -1 (Operation not permitted)
nl80211: Try mode change after setting interface down
Could not set interface wlan0 flags (DOWN): Operation not permitted
nl80211: Failed to set interface down
nl80211: Interface mode change to 3 from 0 failed
nl80211: Could not configure driver mode
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Failed to set interface 3 to mode 2: -1 (Operation not permitted)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0xeeb020)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0xeeb020)
wlan0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss wlan0
wlan0: AP-DISABLED
hostapd_cleanup(hapd=0xeebda0 (wlan0))
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0xeeb020)
hostapd_interface_free: free hapd 0xeebda0
hostapd_cleanup_iface(0xeeb020)
hostapd_cleanup_iface_partial(0xeeb020)
hostapd_cleanup_iface: free iface=0xeeb020
pi@navio:~ $ sudo systemctl status hostapd
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Aut
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor pres
Active: active (running) since Fri 2024-06-07 15:45:02 BST; 10min ago
Process: 596 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON
Main PID: 636 (hostapd)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/hostapd.service
└─636 /usr/sbin/hostapd -B -P /run/hostapd.pid -B /etc/hostapd/ho
Jun 07 15:45:01 navio systemd[1]: Starting Advanced IEEE 802.11 AP and IEEE
Jun 07 15:45:02 navio hostapd[596]: Configuration file: /etc/hostapd/hostapd
Jun 07 15:45:02 navio hostapd[596]: wlan0: interface state UNINITIALIZED->CO
Jun 07 15:45:02 navio hostapd[596]: wlan0: Could not connect to kernel drive
Jun 07 15:45:02 navio hostapd[596]: Using interface wlan0 with hwaddr d8:3a:
Jun 07 15:45:02 navio hostapd[596]: wlan0: interface state COUNTRY_UPDATE->E
Jun 07 15:45:02 navio hostapd[596]: wlan0: AP-ENABLED
Jun 07 15:45:02 navio systemd[1]: Started Advanced IEEE 802.11 AP and IEEE 8
lines 1-17/17 (END)
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
Process: 596 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=0/SUCCESS)
└─636 /usr/sbin/hostapd -B -P /run/hostapd.pid -B /etc/hostapd/hostapd.conf
Jun 07 15:45:01 navio systemd[1]: Starting Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator...
Jun 07 15:45:02 navio hostapd[596]: Configuration file: /etc/hostapd/hostapd.conf
Jun 07 15:45:02 navio hostapd[596]: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Jun 07 15:45:02 navio hostapd[596]: wlan0: Could not connect to kernel driver
Jun 07 15:45:02 navio hostapd[596]: Using interface wlan0 with hwaddr d8:3a:dd:fd:14:a1 and ssid "dragonflite95"
Jun 07 15:45:02 navio hostapd[596]: wlan0: interface state COUNTRY_UPDATE->ENABLED
Jun 07 15:45:02 navio systemd[1]: Started Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
As you can see, wlan0 is still on an external network in “ACM Lab”:
pi@navio:~ $ sudo iwconfig wlan0
wlan0 IEEE 802.11 ESSID:"ACM Lab"
Mode:Managed Frequency:2.442 GHz Access Point: 00:1E:58:25:AC:F3
Bit Rate=65 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Link Quality=61/70 Signal level=-49 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
I tried adding “denyinterfaces wlan0” to dhcpcd.conf but that does nothing. I seem to be just guessing at this point. Any suggestions? Thanks
