Hola, que tal responde este emplificdor? quiero para mis antenas, mas me interesa para bosque, sera que mejora la señal? saludos y éxitos
Greetings
My experience with the Harxon radio has been mostly positive. The most obvious setback is its extra bulk and weight. Additionally you will need to transport a battery or power supply.
If you are outside the Continental USA i would recommend you first try the Emlid LoRa amplifier. I believe if pushes 3 Watts.
It is apparently fully compatible with the RS2 & RS2+. It is also a more economical purchase.
Check with your local dealer
