Is it possible to disable the “auto-update over wifi” thing? We’re using the Reach installed inside a robot, with no Wifi access. The Reach has me stuck at “Please connect to Wi-Fi network and install an update”, and the “reboot and go to the app” button is disabled. Also, SSH access isn’t working (not sure if that’s related).
We communicate with the Reach via the USB/ethernet interface, not wifi, and we’d like to do updates by manually flashing, at a time of our choosing, if possible.
Here’s a screen cap of the page that comes up. I’m assuming (possibly wrong), that the fact that I can’t get a TCP connection or SSH to the Reach has something to do with the update functionality:
The Reach is on a LAN, and has a gateway to the Internet, via the USB<->Ethernet (it has no Wifi access out). Stock firmware. Not sure if it worked in the past (new, untested installation). Edit: the Reach doesn’t have name service working, so I assume that’s why it can’t find an update server).
I am of the opinion that if you can see the Reach updater page, then the ssh daemon is probably running and that you are just having trouble connecting to it.
One thing you could do is port-scan Reach so we can see what ports are open (hopefully port 22). For example: nmap 192.168.2.15
Otherwise, you could explain your network in more detail, like what devices/OS you have, what connects to what, WiFi or wired, and what all the network interface addresses are. Just be as descriptive as you can.
I’ll start another thread with the SSH issue, since it’s separate from my original question. Thanks.
