I have no motors, esc’s, or drone frame but am slowly putting things together. I have a taranis x9d plus that I finally got to bind to a xsr receiver after randomly flashing firmware to transmitter and receiver about a month ago. It has sat on a shelf for a month while i took a brake and built a alt coin mining rig. I finally received a new raspberry pi in the mail after repeatedly failing to get a older one to boot up. Turned out that it was a bad sd card and both will boot up now. I fought through getting the raspberry to connect to computer with ssh over the past 2 days and now can get into the navio on the pi using putty.
Trying to follow this page https://docs.emlid.com/navio2/common/ardupilot/installation-and-running/ on connecting to ground station (mission planner). I am at this portion. (( Specifying launching options)) and figured out that I needed to use (( pi@navio: ~ $ sudo vi /etc/default/arducopter )) instead of (( pi@navio: ~ $ sudo nano /etc/default/arducopter )) to be able to change the ip address of (( TELEM1=“-A udp:127.0.0.1:14550” )) to (( TELEM1=“-A udp:https://www.whatismyip.com/ listing of my ipv4 ip address” )).
I saved it, then reloaded it. I then rebooted and ran systemctl status to verify ip address changed. which it did. However mission planner still does not connect.
Anyone know what I did wrong? Besides thinking I could do any of this that is.
