Hello, I apologize if this is a simplistic question. Will it be a problem to use an RS+ and RS2 as a base-rover (or rover-base) pair? Or should they both be the same model?
Mahalo,
Scott Rowland, University of Hawaii
Hi Mahalo,
You can configure Reach RS2 as a base for Reach RS+. However, in this setup, you won’t get the advantages of working with the multi-band system as Reach RS+ receives only L1 corrections.
Reach RS+ can’t be used as a base for Reach RS2. Reach RS2 expects to receive the multifrequency corrections which Reach RS+ can’t provide.
