Hello,
How can I combine hour OBS’s files into one bigger file ?
example:-
ABCDa.18o, ABCDb.18o … ABCDx.18o into one file
These are base station OBS’s files
Hello,
example:-
No need usually, RTKpost will just read them sequentially. Put all base obs in a seperate folder and specify with folder\*
Thanks Christian, I hadn’t realised you could use wildcards.
Yes, Christian’s advice worked - I’ve marked it as solved
