Hi, hopefully someone can give me a bit of advice.
I use a combination of Agisoft photoscan and Reach RS (for precise ground control points) to build 3d models of landscapes. Using Reach RS, the ground points are collected in ESPG: 4326, however this isn’t an option on the co-ordinate settings in Agisoft. Does any one know which co-ordinate setting I should use in Agisoft ( i live in the north east of England) and do I need to convert the co-ordinates taken by Reach RS?
Also is it possible to change the co-ordinate system in Reach RS?
Any help will be greatly appreciated.
Thanks
Mark
Hi there,
ESPG 4326 is the identifer code for WGS84.
If you import into Agisoft using WGS84 then you can convert it to whatever coordinate system you need.
