for postprocessing of more than 5 points it is a pain to work with the gui version of RTKlib. Where can I get the corrosponding executables to automate the postprocessing process?
Thx,
Tobias
Thx,
Tobias
Isn’t there an answer for my question? Does @emlid simply avoid to publish it? Is so, would it be possible that @emlid publishes a gui versions which can read the survey csv-files and calculate solutions for each survey periode?
And if @emlid does that, could you please inlude a lever-arm correction which takes the flight direction into account? Should be fairly easy. Not so much later you could include the IMU data to make the result even better.
Hi @tobias-dahms,
You can find our RTKLIB version code by following this link.
Thanks for your feature request, we’ll think about implementing them.
Which branch/tags do we have to take ? Master ?
Thank you very much, excuse my ignorance, do I have to compile the win executables myself? I have not done that before… .
I have seen your git before but was wondering about the update times 4 years ago… . Is this the current version?
Ok, thx, than I will learn how to do that.
