Hello,
I have two questions:
When logging the raw files in RINEX format one can enter a
Measured height
From the hint one would conclude it is to the bottom of the receiver, but when one later looks into the Rinex file it does not seem to include the offset from the bottom to the phase center in none of
- Line
ANTENNA: DELTA H/E/N is empty
- if one enters
0m
there should be the phase center offset in my understanding in theAPPROX POSITION XYZ
field (which I think is not).
For the receivers that do not include an antenna this is of course not possible as one could use a different antenna but for the Reach RS2 this could be done automatically.
In my understanding, the wording should be changed to something likeTo the phase center of the antenna
- Line
The word
receiver
should be changed toantenna
for a more precise wording
It would be nice if a hint could be included in the logging of the Base corrections if these are the incoming corrections or in case the device is used as base the outgoing corrections
Colleague and I discussed about it and found out we expected the exact opposite thing but both ways are kind of logical.
