I plan to use a LTE hotspot wired to a Reach M+ via USB OTG to get NTRIP corrections. I now have to chose a data plan for the modem but I have no idea how much data is required for let’s say 24 hours of NTRIP correction.
Does someone have a rough estimation? I have searched many topics but haven’t found any. As I understand most of hotspot users are counting on their own mobile dataplan so I guess the signal is not too data consuming.
Note that the 18-19 kb/s is with many constellations being received (GPS+GLO+SBAS+GAL+QZSS). Many NTRIP providers only provide GPS+GLO which would lower the traffic quite a bit (probably half it).
Thank you for your quick reply. I will start with a 2GB plan a month for the first tests then (60 hours at half the LoRa bandwidth). I should share my real Data usage after the first month.
I have various fixed bases running RTCM3 correction; in general the data usage for either the base or rover receiving the correction is average around 1MB/hour for GPS+GLONASS.
Continuous operation over the period of a month is simple maths, 24x31 around 750 MB. Allow some extra if you’re doing any administration over the link.
