Hi! I am planning to purchase Cheerson CX-OF Optical Flow and connecting it to the UART port. I will like to ask for help in establishing the connection to QGC & Ardupilot to solve the “Position Estimate Required” error.
I am utilizing ArduPilot as the firmware, which is interfaced with MAVROS (MAVLink to ROS). Additionally, the hardware includes APM (ArduPilot Mega) for enhanced control and autonomy.
I can suggest сhecking the resources that provide ArduPilot documentation regarding this CX-OF Optical Flow sensor.
Regarding the establishing connection “Position Estimate Required” error, please check that the device passes the first-time checks and calibrations in the QGC.
Hi @olesia.riman, i have went into the forum to check, however i am curious if Navio2 supports it via UART port as the information provided by Ardupilot uses PikHawk. There were some configurations that i could not find under “Parameters” in QGroundControl.
If the Cheerson CX-OF Optical Flow sensor uses the UART logical level and can be powered by Navio2 (or by a separate power board), the connection is possible. I can hardly advise if this particular parameter is crucial for the ArduPilot. However, maybe some additional answers can be found on the ArduPilot forum.
