I connected Mission Planner to ArduCopter, all looks good. I enabled Joystick and I can arm/disarm the unit (I disabled pre-arm checks, as there is no copter connected yet). All good. I can change the pwm values of channel 1 to 4 using the joystick, verified in Mission Planner -> Status -> ch1in/ch2in/ch3in/ch4in. All good.
However, when I put a scope on the pwm pins, I cannot see any pwm signal. Just to check, I stopped ArduCopter, and ran Navio/C++/Examples/Servo/Servo example, and I can see the pwm signal.
Before looking into ArduCopter’s code, can someone enlighten me as to why there is no pwm signal from ArduCopter?
Btw, re-tested on navio-plus-rtk and it is working. The codebase is still older, I can see it uses pigpiod but navio doesn’t.
Does anyone have a snapshot of the original navio branch when navio-plus-rtk was branched? Happy to diff them and see what were the core changes, and perhaps create a patch set for the latest navio branch…
@keithc Hi, Navio+ is now fully supported by ardupilot master branch and you can use its automatic firmware builds from here - http://firmware.diydrones.com/
