Hi all,
I need to use often transformation and to set it up in the coordinate system (App flow).
But if i want to change the transformation later on e.g. sign or typos…
It is very nasty to create a complete new transformation. I miss actually an edit function…
Thanks and best regards
Alex.
Can you explain a little more in detail what is it, you are trying to achieve?
Hi Alexander,
Editing coordinate systems can be tricky – if any points were collected in this CS, their coordinates should change as well. But adding all the parameters from scratch takes time, so I see your point. Noted the request, thank you!
