A bit of background
Where I am, our jurisdiction functions between both GNSS/Grid and Terrestrial (for height) which makes (I think) the difference between Geoid Heights and Leveled heights deviate between each other (depending on their lineage). This is fine, but when a state control mark has already had a GNSS occupation updated on it, only the Ellipsoid height can be updated, not the leveled height (unless, I think, multiple occupations, minimum number of hours, processing, submission, acceptance, etc are performed over multiple days, not sure).
This is where I’d like an update (or warning maybe when doing so?) when it comes to using Global Points as part of Localisation and not just Local points. Using the Global input means I can input the published LLH of the mark (which is on the same datum, just different units) and the correct Geoid Height gets calculated for the mark. Otherwise I’d need to calculate this through another program which I couldn’t do in the field, to then do a Localisation.
Is this something that could get accepted? Does any one else have any feedback on this?
Joel
Current version 9.11 on iOS
