Hello,
I need the cdc_ether driver to get my huawei e3372 modem up and running.
I have flashed the reach/edison with only slightly modified “original” edison-src-ww-25.5-15 edison firmware where I have enabled the cdc_ether driver.
With that image the modem works perfectly. The problem is that I don’t have the Reach image source. So I can’t make a new Reach image with the wanted driver compiled.
"At the moment ReachView will only run on a Reach/Intel Edison flashed with our pre-built image. "
Will the reach image be open soon? That would be good.
Can I get a reach images with the cdc_ether enabled? (Device Drivers > Network device support > USB Network Adapters > CONFIG_USB_NET_CDCETHER)
sudo insmod cdc_ether.ko will work in the meantime
Thanks!
Kristofer
