Since ReachView 3 6.14 I cannot import .csv files (survey points) to RV3. I am working in “Central Austria” and it doesn’t matter which code (EPSG) I am using-it doesn’t work. Unfortunately I forgot the code using before. Could not find the right setting until now…
Hi Franz,
CSV from ReachView 3 should contact the coordinate system name in the last column. If it’s not, you can check recommendations from our guide about the Austrian system.
Why did it happen in v6.14? Were all your projects removed?
