@igor.vereninov@egor.fedorov Guys any update on getting Reach to work with swipos? I am now back in California and was able to get Reach to work with UNAVCO NTRIP here. Getting Reach to work with swipos NTRIP is the most important as it is for our client. Please give me an update and how I can assist to get things working. Thanks.
The fix will be included in the next release, coming in the next few days. If you want me to provide you with instructions for “beta testing”, write me a PM.
I’ve released v0.4.4, which, among other updates, now sends more complete NMEA GGA messages to the base station.
Unfortunately, we have not been able to receive corrections from your NTRIP provider even with this fix, so there must be something else. Please, post any details you find out.
Hi Egor, I have updated to v0.4.5 and spoke to swipos NTRIP service provider. They confirm GGA messages are complete, so we got past the satellite count. The end result was that corrections were not sent because the system status says “Unable to resolve GPS coordinates;” something to that effect. It was determined that the issue may be that I am in the USA now, so I would have to try again when I am back in Switzerland. At least we’re making progress and it looks promising. Thank you for your support and I will update you when I go back.
open the Run dialog box, then run the Command Prompt program (hotkey: WindowsKey + R, then type cmd) and type: pscp.exe -p -r reach@192.168.43.217:logs .
(assuming that pscp.exe is in the current directory. if not, cd to it or copy it into your current cirectory)
To connect, you will need to use putty or another third-party ssh implementation. After you have determined the IP address, type it in along with username reach. The password is also reach.
With v0.4.6, we have added a check for application integrity which fixed the problem with logs not downloading. I would advise to try using ReachView in a different browser.
