I imported the CSV file that was recorded in Reachpanel. The file was imported into ReachView3 and then I turned around and exported it back out so I could bring that file into Emlid Studio for Stop and Go processing. But I get an error that “Point Time Stamps can not be converted”.
Is there a utility yet that will simply convert the Reachpanel CSV file so that it can be imported in to Eml Studio? If not, is there a special way that the ReachPanel CSV version needs to be converted to Reachview 3 format?
You did the right thing. The easiest way to migrate from Reach Panel to ReachView 3 is to import and export the CSV. But it seems something went wrong. Can you share the CSV from Reach Panel? I’ll check it myself.
Sorry, I confused both of us! The only way to make Reach Panel CSV work in Emlid Studio is to edit it manually. ReachView 3 doesn’t import and modify time intervals.
I did it for you. But I need to note that surveying with ReachView 3 is the right choice
Thank you Svetlana! I have switched to RV3 and this was for a buddy that also uses Emlid. So I have let him know he had to make the switch to use Studio. In the past, I had actually used the RV Panel because I would be multitasking and I would start the “measure” and then leave with the device (phone or tablet). When I returned, I would reconnect, accept the capture, and move one. But with RV3, the I assume the device must alsways be connected since the Measure is being saved to the device and not the RS/RS2 unit.
But now I just use a dedicated tablet mounted to the prism pole RV3 is very nice!
