Hello,
I have an issue connecting with the readytosky 915mhz telemetry set that is recommended for the navio2 and rpi3b+ and QGroundControl as well as APM Planner. I currently have one of the devices plugged into the UART port on the Navio2 and the other in the USB port of my MBP.
If I view About This Mac->System Report->USB, I can see the device connected. So I don’t believe that is an issue.
I have solid green lights on both telemetry devices, and have no issue connecting over wifi with the TELEM1 var set to my IP like so: TELEM1 ="-A udp:192.168.1.4:14550"
However, when I try to connect via the Telemetry device, nothing ever happens.
I have the telemetry plugged into the UART port on the navio2 and the other telemetry module into the USB port on my macbook pro. Both lights are solid green and there is no option for usbserial.
@mlebret i don’t think that’s it for 2 reasons. I have already installed the driver, and secondly my Macbook pro can read it. Please see the image I posted previously:
